91 5.0 with erratic high idle
1993SSP
1,194
Ky
Got the car out for a drive today and cleaned it up. The idle is fine when it's first started, but during driving it wants to idle at 2K rpm, I have checked all my connections. What could be the culprit?
I vote for dirty/sticking idle air control valve aka iac but a few other examples could be...
vacuum leak
sticking throttle body or linkage...if the throttle plate is resting against the stop when its doing it then this isn't the prob.
I would unplug the iac when its doing it and see what it does then go from there...
the IAC was my first suspect, I'll check into it further when I have more time tommorrow, whenever it does it I can turn off the engine while driving and re start and the idle goes back to around 900rpm, just annoying as hell :mad:
The voltage should be .095 right?? I pulled the IAC, It has been modded so that the valve is bypassed, the metal in the middle has been ground down. I'll prob go with the TPS, the idle would sometimes go back down when I would also tap the gas while in neutral.
I just recently had the same exact problem, not with the stang but, I thought it was the IAC but if I unplugged the tps my car would idle fine, plug it back in and the idle would climb to about 1900rpm's.
