92 5 lug conversion question
  • Thread starter Thread starter gaskincrew
  • Start date Start date Oct 30, 2011
G
gaskincrew
22
  • Oct 30, 2011
i have five lug conversion on my car when i purchased it, it has pony wheel from around 2000 gt on it ,but the front centre cap will not fit, where and what do i need to do to fix it,where the centre cap will pop on and no hit dust bearing cap? thanks.
88LX
327
Chicago, IL
Oct 30, 2011
  • Oct 30, 2011
i think youre going to have to provide more details as far as what "method" was used to achieve that 5 lug conversion. i have completed that project, using 95 spindles and NRC bracket/axle kit so i know about that method.
FOX87NOTCH
30
ohio
Oct 30, 2011
  • Oct 30, 2011
ur car probably had the el cheapo 5 lug conversion done with ranger hubs, unfortunately u will run into alot of the later wheels where the center cap will not fit. only wheels that will work with that setup are the cobra r wheels.
LarsD
2,680
119
123
Texas
Oct 30, 2011
  • Oct 30, 2011
Yup sounds like just the rotor conversion. You are still going to be pretty limited on wheel selection unless you swap spindles onto it. Until then you can either cut a hole in the center cap, or just not run the center cap at all.
G
gaskincrew
22
  • Nov 2, 2011
so what front spindle or hub do i need to make the front wheel centre go on, there has to be a diff spindle or rotor to put on to make it work,,my car is a 93 , and im shur it was the el cheap o coversion..
ID89GT
1,659
18
49
Spokane Valley, WA
Nov 2, 2011
  • Nov 2, 2011
Sounds like you have what I used to have. You will need sn95 spindles. 94-95 will be your best bet as to what year you want
bigvino
259
Corpus Christi, TEXAS
Nov 4, 2011
  • Nov 4, 2011
yup, the 94-95 front spindles will absolutely fix that problem, go to any junk yard around your town and you can pick them up for about 80 bucks
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
