92 GT no start
92 GT no start.
I have spark, fuel pump works but does not prime I have to tap the relay to start pump and it stays on. I have more than enough psi to run the car, but the injectors do not fire. I pulled a connector checked an old injector, no click or puffs of air. I can't pull any codes from the computer I changed the battery right before this happened so I'm getting 00 on the reader. Has anyone ever had this happen? How did you fix it?
Thanks Chris
Check for 12 volts [with the key-on] to the injector connectors. They get accessory 12 volts and a pulsed ground.
If you have 12 volts but no pulsed ground, check your TPS sig return to be sure it's around 1.0 volt.
And of course, see JRichker's Cranks but no start checklist.
Good luck.
