installed 94-95 t-5 with the m2 bell last summer and put roughly 750 miles on the setup. i noticed a slight leak over the winter and it turns out the bearing retainer was leaking a little. however, i did find a much bigger issue with the wear on the input shaft. you could clearly see a wear pattern of only 3/8 of an inch. based on this i am going to install a new roller pilot bearing and and have a new sleeve machined based on the t-5 swap on the .net site.
while the 94-95 might help with the longer input shaft, it is not enough and you will definatly need to do something with the pilot bearing. the other other option would be using the t-5 bell but that may bring up other issues.
Or is that just Murphy's Law??
