94 Cobra Running Awful Need Help
Cobra0213
Hey guys i have a 94 cobra that is running awful. When i first get in after a cold start and start to drive there is barley any power when i am pressing the gas pedal. After about 10 or so minutes after its warm it drives a little bit better but still very noticeable. I have checked the fuel lines and have no leaks, new spark plugs and harness. There are no check engine lights on just a low coolant light but its always been on since before the issue. Need help any advice works
Welcome to Stangnet.
Not all codes will flash a CEL.
I'll move your thread over to our '79-'95 tech forum. A guy named Joe will help you out. @jrichker He was probably smarter than me at two years old than I am at 55.
Good to have you with us. Show a picture or two of your ride, it's always good to see a cobra!:nice:
Dump codes sticky
Look at the top of the 5.0 Tech forum where the sticky threads are posted. One of them is how to dump the computer codes. Codes may be present even if the CEL (Check Engine Light) isn’t on. You don’t need a code reader or scanner – all you need is a paper clip, or if your lady friend has a hair pin, that will do the job.
I highly suggest that you read it and follow the instructions to dump the codes. http://www.stangnet.com/mustang-forums/threads/how-to-pull-codes-from-eec4.889006/
