My car seems to have some serious electical issues... It sputters and pops sometimes like its running on 4 cylinders, backfires... the engine is a 306, canfield's, msd ignition,10:1 comp, etc etc.... i have gone and gave it a tune up to try to help my issues... new plugs, new wires, new dis. cap, new blaster coil, new o2 sensors... and it seems everything i do makes the problem worse... i was wondering if anyone has had any similar problems and what was the fix... i know it could be a wide range of things but at this point im open to any ideas.... also before the car would seem to run fine then start missing and backfiring and running super rough then sometimes it would run fine again... now it has been sitting for a few days and after i get it started it runs horrible all the time... thanks for the help! brian
Car wouldn't go through an intersection from a dead stop to save its life before the light turned red again and it got worse as I drove it. 50mph, 40, 30, 25, and then dead stop. Indeed check the timing at the distributor first then move beyond up to the spark plugs firing order ( I've done that one too
Have you replaced it?
