  • 1994 - 1995 Specific Tech
94' supercharged
  • Thread starter Thread starter aleborjas
  • Start date Start date Apr 24, 2006
aleborjas
610
  • Apr 24, 2006
hi i'm building a 94' with stock short block, GT40P heads(170LBS static presure on each cilinders), explorer intake ported, 65mm TB, 42pounders injectors, 80mm maff, stock cam, 1.7RR's, vortech S trim 10pounds of boost, 1 5/8 LT's, 2.5 pipe....
my problems are 2 that they are getting me pist off, 1 is i made a custom chip that my total timing is 24º (little retarded) and 10º base and im tired of hearing the engine nockling alot, i made a some changes i tok off the computer chip and i the spout off and put the timing on 20º static and i still hear pining what can i do?
2 the other one is i have no vac the vac is on 9 inches on 1000RPM's and i cheked all the vac lines and the car smells fuel and the gasket between both intakes is sealing, i cheked the valves again they ahve 1/4 turn after the pushrod stops what else can it be?
i really need help with this car....
aleborjas
610
  • Apr 24, 2006
anyone??????????
R
94 mustang has missfire after nos use...help!!!!
  • randyb1976
  • Jul 5, 2010
2K
1994 - 1995 Specific Tech Jul 17, 2010
DEFWISH
94' supercharged
  • aleborjas
  • Apr 23, 2006
1994 - 1995 Specific Tech Apr 23, 2006
bimmertech
94' supercharged
  • aleborjas
  • Apr 23, 2006
Fox 5.0 Mustang Tech Apr 24, 2006
04sleeper
