  • 1994 - 1995 Specific Tech
95 cobra fuel pressure help!!
  • Thread starter Thread starter flygilmore
  • Start date Start date Jul 8, 2009
F
flygilmore
33
  • Jul 8, 2009
I have a 95 cobra...stock motor w/a V1 s-trim installed. Fuel pressure has always been(while at idle 39-40psi) but lately, it has dropped down to around 30-31 @ idle and doesn't seem to increase with throttle. This has happened slowly and I can't put a finger on when it happened. Also, the car when coming to a stop, when the clutch is pressed in, drops rpm's quickly like it is going to die and has several times. Other than this, it appears to be running normal-of course I haven't been pushing the car at all til this is figured out. It has the stock FPR, 255lph in tank etc. FMU, 24lb injectors recent fuel filter ( 2,000miles ago). I am not sure what is going on here. I need some opinions to try and find the source of the lower pressure and dying issue.
I searched the threads and it says 31-32 @idle vaccum on is good, but mine has always read 39-40 so I am basing on this. Thanks for your help!!!
F
flygilmore
33
  • Jul 8, 2009
Just went out and checked a couple of things. When I unplug the vaccum from the top of the FPR, the fuel pressure only goes up 1lb. to around 33lb. total. Also, when I turn the car off, the fuel pressure drops all of a sudden to around 24lb. I figured these things might help the diagnosis.
Thanks!
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jul 8, 2009
  • Jul 8, 2009
You've done some good diagnosis on the issue. I believe that the fuel pumps don't fail that way, they usually just don't run. A bad fpr on the other hand, can give the symptoms you're describing. With the vacuum line off, the fuel pressure should be 38-40 at idle. 33 is certainly too low, so I would say your fpr is shot. Time for a new one.
95Vert383AOD
1,133
34
69
New Bedford, MA
Jul 8, 2009
  • Jul 8, 2009
+1 and get one of them fangdangled adjustable ones
I
inphiniti
412
Providence, RI
Jul 8, 2009
  • Jul 8, 2009
i just went with an aeromotive fuel pressure regulator, awesome so far
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jul 8, 2009
  • Jul 8, 2009
Maybe, depends on his emission requirements in his state. In CA where I am, they're very illegal. Of course, no one noticed my bright red Aeromotive one for ages. Anyway, I disagree. An adjustable FPR is only a patch for a problem IMO. If you need to boost your fuel pressure, you really should get a proper tune. Flygilmore didn't mention any issues with running lean before the fuel pressure dropped, so I would simply recommend an OEM replacement.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
C
  • Locked
Fuel pressure too high
  • Canadianfox
  • Jul 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2025
