I posted this in 5.0 tech. Didn't know there was a seperate forum for 94-95. Can anyone help with some info on this problem?
Car idled at 2100 rpm when I started on it. First, this car is a little different. Last year, the 95 computer was ditched cause it would not idle at all. It has a computer out of an 89 GT manual trans. It also has a bigger cam in it but am still trying to find out which one. Doesn't sound very radical but it won't idle so.. its also got a BBK CAI on it. Stock MAF, stock TB.
Cleaned the IAC, TB, and MAF, and EGR. EGR operates normally and is closed at idle. I got the idle down to 1500 using the base idle adjustment proceedure-computer reset, remove IAC harness, start car and set base idle. Could not get it below 1400. Car off reconnect IAC start with no load for 2 min, off and back on with everything turned on for 2 min. The base idle adjustment screw is off the stop. THe throttle blade is as closed as it can get.
It starts high at 2000 rpm then drops to 1200-1500 but takes a good 45sec to 1 min to drop. Taking the IAC harness off now has little change as it should. TPS is .980 exactly.
One interesting thing I found. If I pull the MAF harness off it idles perfectly. Jumps right back up when the MAF is reconnected.
I haven't checked the 10 pins or the O2 heaters yet.
I would like to know a list of grounds specifically for the 95 Cobra so I can check all that. I suspect they are pretty much the same as my 93 but want to make sure. I couldn't see any ground from the intake to the firewall.
It seems that unmetered air is getting in but I sprayed the front and back of the intake and where the upper attaches and all over the throttle body and CAI. No change in engine speed at all. Seems tight.
