I have a 88 Saleen… Cali mass air, rebuilt 347, e303, BBK 70 mm TB with Pro M 77 air meter calibrated to my 30 lb injectors… Bisanni equal length into BBK 2.5 high flow cats, SuperChips chip… engine had 8-10 k miles before this problem started…
While driving random times after start, cold or warm, engine rpm hangs at 2100! Since the issue, removed chip, installed new coolant and air charge sensors, EGR, BBK TB with new TPS, new BBK calibrated mass air meter…. Yes base idle reset, TPS set to .87v…. Timing at still at 13
-If I shut car off, problem goes away for a few minutes.
-if I unplug IAC idle drops to normal, plug it in and idle jumps back up
-if I unplug TPS, idle drops to normal, plug it back in idle stays normal.. drive the car and within a few minutes, idle jumps back up.
