95 gt ac hoses
The 74 302 has a different balance on the flywheel, flex plate, harmonic balancer than a 5.0 engine. Have you investigated this to see if the 94-5 V8 accessories will swap?
And the starter for a sn95 5.0 uses a 'mini ' type starter, I'm not sure if the v6 starter is the same.
Yes I have. Everything is balanced correctly and accessory brackets from 95 all line up fine. I just want to make sure I get the correct stuff for moving the ac compressor. I found out that the starters are the same they have the same part number.
II take it the compressor bolts up to the SN accessories? Just go to O'Reilly's or where ever and buy AC hoses for a stock SN GT if you have the accessories for a stock SN. AC lines aren't terribly expensive.
Kurt
