:( 95 mustang 3.8 dash wiring
craigpost19
i need the dash wiring diagram so i can wire it or if someone is selling a wire harness but i need the diagram to pass inspection its the last thing everything works on it except the speed and milage can anyone help please:(
Have you checked the speed sensor? If the sensor isn't sending a signal back to the cluster or PCM, your speedo will cease to function. It's located on the drivers side of the transmission. I'm not sure how to test them though. I doubt its a gauge cluster problem.
Project details for better help
I do not have a wiring diagram from the 95 MY. Sorry.
But it might help if you explained the project or problem. I suspect that you are trying to adapt wiring from one MY to a different MY. Ford made a lot of changes in 1996 and again in 1999, so the MY of what you trying to swap/exchange/adapt can be important.
