95 Mustang
hot1mama
Ok I am a chic and I have a 95 Mustang I have put fuse ater fuse in my car and still I have no turn signals, no rear defrost and air bag light is on can some one please help oh and i need to figure it out before we get this so called blizzard grrr
No turn signals - Most likely cause is bad flasher. THough always do the obvious things like checking bulbs, etc. Also possible that the actual switch is bad.
No rear defrost - Most likely cause is the lead going to the grid fell off or broke off. Visual check, theres one on either side of the glass. Also possible the switch or relay is bad or the grid is destroyed. Usually scraped away.
Air bag light - Most common issue is the clockspring which sits under the steering wheel. THough it could be one of the crashs sensorsor the modules themselves. Does your horn work? Cruise control? If horn or cruise dont work, 99% chance its the clockspring since theyre wired through the clockspring along with the air bag circuitry.
Also, if youre putting in fuses and they keep popping, you have a short to ground that needs to be chased down.
And yes, these storms sure are lovely. Very glad I no longer have to drive my Mustang in the winter.
