I've read that the 99 and newer rearend housings are a little wider than the 98 and older? how much wider are they ? just curious
they are wider... how much... hmm a few inchessn98gt said:I've read that the 99 and newer rearend housings are a little wider than the 98 and older? how much wider are they ? just curious
tarch said:they are wider... how much... hmm a few inches
so do you just want to fill out the wheel wells? then just go get a set of 10.5's to put out back!!! peacesn98gt said:thanks... anyone know exactly how much wider? I'm thinking about getting one, having the tubes welded and putting all my new stuff in it and just swapping it with the stock one in my 98. I want it to be about an 1 1/2 to maybe 2 inches wider to kick the rear tires out a little more.
86strokerlx said:I was told a while ago that they are 1.5" wider on each side, for a total of 3" wider. This is from Stangman393. Jeff knows his Mustangs and has measured a lot of parts. I haven't had a chance to measure but you may be able to tell by the track width of the 98's vs. 99's.
Tylerb59 said:Don't bother wasting your money on something like that. Wider tires and spacers will do 'ya well.
RazorsStang said:I swapped a 98 Rear axle into a 00 a couple years ago, very straightforward and easy bolt on. If you're willing to waste a whole day doing it that is. The bolt sizes are different, just use your existing control arms and bushings with the new housing, everything fits e-z.
I did my swap to switch out a 7.5 with an 8.8. I think doing it only to make your tires stick out the fenders is a little crunch on the wallet. The spacer idea is a much better approach imho. Besides, there are enough Stangs on the streets looking like they were assembled south of the border. Do you want to join in on the Mexi-Stang bandwagon? Lowrider GT? Please don't put in blinging 100 spoke rims!
03yellowvenom said:Dont forget to get that new lic. plate frame for all the tail gaters
Its the only time you'd ever be in front of me at the tracksn98gt said:haha... very funny... I'll put it on the back just so you can read it while I'm pulling you at the track....
someday
03yellowvenom said:Its the only time you'd ever be in front of me at the track
