cold96snake 20+ Year Stangneter Jan 26, 2004 817 1 39 Truly, out to sea Jun 8, 2005 #1 Jun 8, 2005 #1 Will the stock 24 lbers plug and play in a '95 gt 5.0? Or do I need a harness adapter?
z9_87 New Member Apr 16, 2004 332 0 0 Urbana, IL Jun 8, 2005 #2 Jun 8, 2005 #2 They might. Probably won't run to well. You could get a new mass air(not sensor) calibrated for #24 injectors
5.0's 4 ever The #1 Stunna Founding Member Jan 22, 2000 5,794 0 76 Orlando, FL Jun 8, 2005 #3 Jun 8, 2005 #3 Both cars use the same old style fuel injector so they will plug in no problem. But like z9_87 said you need a MAF calibrated to 24lbs injectors after the swap.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,351 18,086 224 Massachusetts Jun 8, 2005 #4 Jun 8, 2005 #4 They will work, but you need to calibrate for the 24's either with a Chip or MAF
