  • SN95 4.6L Mustang Tech
96 Gt And It Is Misfiring On Cylinders
  • Thread starter Thread starter Bog AL 1980
  • Start date Start date Dec 6, 2016
1 of 2 Next Last
Bog AL 1980
Active User
Dec 6, 2016
11
  • Dec 6, 2016
I have a 96 gt and it is misfiring on cylinders 1 and 6 I have changed the ec, plugs, wires and the coil pack can anyone give me any ideas please and thank you
Bog AL 1980
Active User
Dec 6, 2016
11
  • Dec 7, 2016
I have a misfire on cylinders 1 and 6 I have replaced the ecm, plugs, wires, and the coil it is still misfiring cylinders 1 and 6 can anyone give me any ideas on what the problem could be please and thank you.
squeak93
2,325
405
164
Joplin, Missouri
Dec 7, 2016
  • Dec 7, 2016
Do you have any codes?
Bog AL 1980
Active User
Dec 6, 2016
11
  • Dec 7, 2016
No
squeak93
2,325
405
164
Joplin, Missouri
Dec 7, 2016
  • Dec 7, 2016
Have you done a compression and/or leak down test?
You need air, fuel and spark. You need to find which one is missing.
Bog AL 1980
Active User
Dec 6, 2016
11
  • Dec 7, 2016
You need air, fuel and spark. You need to find which one is missing.[/QUOTEwhat do I need to do those test
Bog AL 1980
Active User
Dec 6, 2016
11
  • Dec 7, 2016
What do I need to run these test
squeak93
2,325
405
164
Joplin, Missouri
Dec 7, 2016
  • Dec 7, 2016
A compression tester and the correct mod motor fitting.
Bog AL 1980
Active User
Dec 6, 2016
11
  • Dec 7, 2016
Ok thank you
squeak93
2,325
405
164
Joplin, Missouri
Dec 7, 2016
#10
  • Dec 7, 2016
  • #10
Pull all the plugs first so you don't kill the battery (Helps to put it on a slow charger). Check each cylinder one at a time and write down the results. They will be 120-160ish (results may vary) You're looking to see that all are within a small percentage of each other. Hopefully that makes sense. If you have an issue on those cylinders related to head gasket, broken spring, valve issue etc.
Bog AL 1980
Active User
Dec 6, 2016
11
#11
  • Dec 7, 2016
  • #11
Yes it makes sense and thank you very much
Davedacarpainter
SN Certified Technician
Nov 28, 2015
11,833
11,634
203
Discordia
Dec 9, 2016
#12
  • Dec 9, 2016
  • #12
Welcome to stangnet.
Sorry I missed your post, I would have replied sooner.
I'll move you thread to the '96-'04 tech section, you'll get some help there.
Good to have you with us.
trinity_gt
3,125
81
99
Canada
Dec 9, 2016
#13
  • Dec 9, 2016
  • #13
I'd do a compression test next.
Bog AL 1980
Active User
Dec 6, 2016
11
#14
  • Dec 9, 2016
  • #14
Thank you
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 9, 2016
#15
  • Dec 9, 2016
  • #15
Are you aware that cylinders 1 and 6 have a common coil pack circuit? To me this is too great of coincidence to ignore. Since you have replaced so many parts, we should assume the common causes such as coil packs, plug wires, spark plugs are OK.
IF this were my car I would confirm that the coil pack is actually getting a pulse from the PCM. At the coil pack inspect the electrical connector looking for bent/pushed pins. Use a "noid" test light between pins 1 & 2 and pins 3 & 2. IF not low voltage ignition pulse look for a problem in the PCM signal return or a bad PCM coil driver.
Bog AL 1980
Active User
Dec 6, 2016
11
#16
  • Dec 9, 2016
  • #16
I have replaced the PCM or ECM twice the first time it ran OK but still didn't have the power I had before the original went bad but after about a week it started misfiring again so I changed plugs wires and coil and that didn't fix it so I replaced the ecm again and it still didn't fix the problem
trinity_gt
3,125
81
99
Canada
Dec 9, 2016
#17
  • Dec 9, 2016
  • #17
Any work done on the car recently that involved, say, removing the engine or cylinder heads?
If so, any chance a wiring harness was pinched during the process?
Bog AL 1980
Active User
Dec 6, 2016
11
#18
  • Dec 9, 2016
  • #18
No work like that has been done to it it is a daily driven car for me I bought it on February the only thing I've had to do to it was put a ball joint on it the car was running great I stopped one evening and got gas and when I started it up to go home it was misfiring and the check engine light started flashing a friend scans it for me and found that cylinders 1 and 6 was not firing that's when I changed the ecm and it last about a week then started again so I changed everything else and the ecm again but didn't fix the problem this time
Herb Butler
25
Fairbanks, Alaska
Dec 14, 2016
#19
  • Dec 14, 2016
  • #19
Check the ground wire between the engine and chassis. Also check the continuity of the four wires to both coils. PCM pins are:
26----darkblue/light blue
52----red/light blue
78----pink/white
104--red/yellow
You'll need a DVOM and a long low gage wire to do this.
Herb Butler
25
Fairbanks, Alaska
Dec 14, 2016
#20
  • Dec 14, 2016
  • #20
Another test. Check the fuel pressure at the injector supply and also check the operation of each injector. A new set of injectors is expensive but worth considering.
1 of 2 Next Last
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
J
Which cylinder is which? 3.8L 2004
  • joeybuddy96
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 24, 2026
joeybuddy96
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
H
Misfire cyl 2 under 3200 RPM, not the coil or injector
  • Hydranmenace
  • Nov 14, 2025
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Nov 14, 2025
Hydranmenace
H
