  • SN95 4.6L Mustang Tech
98 4.6 long tube vs shorty's
  • Thread starter Thread starter katrider
  • Start date Start date Oct 2, 2011
K
katrider
  • Oct 2, 2011
hi guys,,,glad i found this site,,,looks great,,,,bought a 98 gt 4.6 5spd,,,first mustang,,, swapping a 98 police engine into my car,,,after pulling the motor,,i see that trying to install headers at a later date would prove diffucult,,my question is what are the pros and cons of the long tube vs the shortys,,,any installation issues,,,as well as any tips,,,thanks again for the great site,,,
GDawg
1,469
Nevada
Oct 2, 2011
  • Oct 2, 2011
My car is lowered and honestly I don't think I could put in LTs that wouldn't drag.
D
Deleted member 38176
Oct 3, 2011
  • Oct 3, 2011
Both are a pain in the as to install. Probably one of the most difficult jobs to do on these cars.
Short tubes do absolutely nothing. NOTHING.
Longtubes probably yield the most power of any "bolt-on" mod (around 20rwhp). After I installed mine it felt like I gained 30rwhp. The difference was incredible.
LarsD
2,680
119
123
Texas
Oct 9, 2011
  • Oct 9, 2011
If you have the engine out now is the time to do them. Make sure to get a set that don't interfere with trans removal. Mine is lowered a bit and has Hookers on it. You will drag everywhere however.
D
Oct 10, 2011
  • Oct 10, 2011
79'293stang
505
11
29
Cedar Rapids, Iowa
Oct 10, 2011
  • Oct 10, 2011
I installed a set of MAC Ceramic coated long tubes onto my friends 98, fitment was really good and he had no dragging issues on his lowered car.
It was a real pain, we had it on a lift. As far as install goes we had to remove the starter, steering shaft, dipstick, unbolt the engine and raise it several inches then remove the engine mounts. Once we got them in place getting the bolts in was a major pain but once we were done and everything reinstalled the payoff was pretty amazing, it felt like a fairly good increase in power. Overall time for install was around 4hrs with a lift and lots of swearing.
Rougestang
59
florida
Oct 17, 2011
  • Oct 17, 2011
I put Mac Long tubes in my car by myself in one night. I will never do it again. To say it was A pain in the arse is an understatement. Unless your going with a forced induction, long tubes won't have huge gains in performance, but do sound a little different than stock manifolds or shorty's or mid-length..etc..etc... Of course, this is assuming you have a different mid- pipe for it as well. Mine makes it hard to take the tranny off, and pretty much do anything to remove the engine. My car is also lowered, and they do drag. I almost wish I went with shorty's. I would recommend visiting BBK's website. They had a video of all the different kinds of headers, and went over them a little. You might be able to find it on youtube as well.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Oct 18, 2011
  • Oct 18, 2011
I have mac long tubes and im lowered well into the 2" range and I have yet to scrape my headers...even with portliness which were just a little higher than the coilovers I have now I never scraped
LarsD
2,680
119
123
Texas
Oct 18, 2011
  • Oct 18, 2011
<------Jealous
I scrape pulling into my shop if I don't hit it just right.
LarsD
2,680
119
123
Texas
Oct 18, 2011
#10
  • Oct 18, 2011
  • #10
<------ Jealous
I scrape pulling into my shop if I don't hit the correct angle just right.
Dark04GT
758
62
59
NC
Oct 18, 2011
#11
  • Oct 18, 2011
  • #11
With my exhaust my midpipe scrapes, not my lt's.
Dark04GT
758
62
59
NC
Oct 18, 2011
#12
  • Oct 18, 2011
  • #12
N8Dogg98
3,872
238
184
MN
Oct 18, 2011
#13
  • Oct 18, 2011
  • #13
If you're scraping with LT's you should consider replacing the engine/trans mounts.
3,287
24
69
Broke
Oct 18, 2011
#14
  • Oct 18, 2011
  • #14
Shorties are utter crap.
Rougestang
59
florida
Oct 18, 2011
#15
  • Oct 18, 2011
  • #15
I should clarify, it's my mid-pipe that scrapes, not the long tubes.
AZmustang98
373
17
Flagstaff, Arizona
Dec 11, 2011
#16
  • Dec 11, 2011
  • #16
I am looking at Macs. Do they allow for removal of the transmission to replace the clutch?
Three50won
1,135
64
69
Dec 14, 2011
#17
  • Dec 14, 2011
  • #17
katrider, shorties DO improve power and performance. I had them installed on my 03 a few years ago (not anymore tho) and I felt the difference they make...and I was skeptical back then. This was in a high compression engine. I felt it more in the upper RPM's. The car had a cleaner and easier pull. It's hard to look at stock manifolds in comparison to shorties (even crappy shorties) and say that shorties do nothing. They obviously are inferior to LTs but I doubt anyone would choose stock manifolds over shorties. The only issue with LTs that I know of are ground clearance and you might have to run a Flaming River steering shaft. You might need the steering shaft with equal length shorties as well. And the O2 sensors might not reach so you might need a pair of extenders. It's best to go ahead and get all these things beforehand so you're not stuck waiting for them. And you're obviously gonna have to get an X/H pipe for LTs if you go with LTs.
trinity_gt
3,125
81
99
Canada
Dec 14, 2011
#18
  • Dec 14, 2011
  • #18
Does anyone have dyno evidence showing the gains to be had with long tubes on an NPI-headed 4.6?
The exhaust port on those things stalls at something like 0.350" valve lift and I just wonder what the gain/pain ratio is when you uncork the exhaust system downstream of those lousy ports.
N
WTB/Trade 1-3/4 Long tube or shorty headers for foxbody
  • nhlxpony
  • Jan 8, 2025
  • Exhaust Parts
Exhaust Parts Jan 9, 2025
nhlxpony
N
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
