  • SN95 4.6L Mustang Tech
98 auto with 4.10
  • Thread starter Thread starter beckham23yl
  • Start date Start date Jan 19, 2006
beckham23yl
  • Jan 19, 2006
hey guys, i have a 98 auto and want to put in a 4.10 gear with SCT2. i read earlier forums, there are mix comments weather SCT2 can correct the speedo since pre-99 has mechnical speedo. thanks i would like to stick with SCT2 rather than speedcal
sgarlic
3,085
Jan 19, 2006
  • Jan 19, 2006
http://www.brothersperformance.com/shop/mustang/brospeedcal.html
Refer to the portion which reads, "Can also use on 94-98 mustangs instead of using speedo drive gear for a more accurate speedometer calibration."
And, it's 10 bucks cheaper than the Dallas Mustang one.
Outlaw97GT
234
Redneckville, Tx
Jan 19, 2006
  • Jan 19, 2006
They SCT won't fix the 96-98 speedo, but still get it. It will do alot more than just that.
Just use both, the STC for the tune and the speed-cal for your speedo....
Bubba Z.
88
Tallahassee, FL
Jan 19, 2006
  • Jan 19, 2006
You'll need a speedcal for your '98 since the speedometer is mechanically linked, not electronically linked. Can only speak for the Dallas Mustang speedcal since it's the one I have. It conveniately sits underneath my shifter bezel and you adjust using a series of DIP switches. A very nice device.
A SCT tuner will help with the shift points and other things if you plan other mods.
1LowGT
294
st louis mo.
Jan 20, 2006
  • Jan 20, 2006
yep get the speedcal i have a 98 and the speedo is still off and i changed the gear which is only accurate to a 3.55 anyway,i learned this all after buying my diablo to fix the speedo.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
