  • SN95 4.6L Mustang Tech
99 GT has a whistle that changes with rpm. what is it?
  • Thread starter Thread starter fiveoho
  • Start date Start date Jul 20, 2008
fiveoho
1,958
TN
Jul 20, 2008
  • Jul 20, 2008
bone stock 99 5 speed. idling it doesnt seem to have any noise at all but when driving it has a whistle ( strangely resembling the sound of a quiet supercharger ) and it changes with more and less throttle. i think the whistle is coming from the back of the car but im not really sure. its not the fuel pump is it?
thanks
RedDaemon
3,470
9
108
Atlanta, GA
Jul 20, 2008
  • Jul 20, 2008
thanks
throw out bearing. good thing u want to change ur clutch
fiveoho
1,958
TN
Jul 20, 2008
  • Jul 20, 2008
so it can make noise even without your foot on the clutch?
J
jprovence
195
Albany, OR
Jul 20, 2008
  • Jul 20, 2008
yeah it can, it would whine going down the road.
fiveoho
1,958
TN
Jul 21, 2008
  • Jul 21, 2008
learned something. i only thought the TOB would make noise when pressure is on the pedal. car needs a clutch anyway. guess i might can kill two birds with one stone
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 21, 2008
  • Jul 21, 2008
open the hood and raise the rpm's and listen near the iac valve and it's tubes.. if you hear the noise then raise the rpms at the throttle body and disconnect the IAC while it's making the noise and your opening the throttle by hand and see if the noise stops..
Some 4.6's will get a loud wistle or other strange noise from the iac.
Might not be it but it's worth checking since it's easy.
fiveoho
1,958
TN
Jul 21, 2008
  • Jul 21, 2008
i appreciate the advice. i will check. if thats what it is making noise, is it hurting anything?
Hardtop68
193
Wherever they need me
Jul 21, 2008
  • Jul 21, 2008
I got a whistling noise coming from the alternator... I thoght it was a bearing but it was the diode bridge or rectifier... use a mechanic sthetoscope...
Mike97gt
it doe snot
10,633
Jul 21, 2008
  • Jul 21, 2008
no but it's annoying..
cobra vodan
12
Utah
Jul 21, 2008
#10
  • Jul 21, 2008
  • #10
If it's a whistle I would look for a possible vacuum leak, although that should set the check engine light. If it's a squeak I would look at the idler or tensioner pulleys.
Good luck,
Dan
Mike97gt
it doe snot
10,633
Jul 21, 2008
#11
  • Jul 21, 2008
  • #11
BTW a tob noise is easy to check, press on the clutch lightly and see if it changes or goes away..
they tend to chirp at idle when your foot is off the clutch when they are bad, some of them will screech when driving..
fiveoho
1,958
TN
Jul 21, 2008
#12
  • Jul 21, 2008
  • #12
well i popped the hood, started it and gradually changed the idle from under the hood. i could not get it to whistle for nothing. no noise inside the car either. its like it only does it while moving but still changes with throttle
H What 4.6
56
#13
  • Jul 21, 2008
  • #13
maybe its coming from the speakers if so its a bad ground from the radio
or the rear whining
Killa
1,006
56
49
Jul 21, 2008
#14
  • Jul 21, 2008
  • #14
I dont know if any of you ever own a turbo car, I have BOV ( blow off valve ) on my turbo Eclipse GSX AWD, it make a whisssssssssssssssss sound every time I change the gear.
my stang had TOB bad and it making the same sound, when I step on the clutch make me miss my old car . Im going install new clutch if I find a place that I can trust, that charger me under 500 buck.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sep 12, 2026
AlexM556
A
