  • SN95 4.6L Mustang Tech
99 GT still missing......
  • Thread starter Thread starter Kappa2006
  • Start date Start date Dec 10, 2006
First Prev 2 of 2
ab 281 gt
123
Irmo, SC
Dec 13, 2006
#21
  • Dec 13, 2006
  • #21
Good luck bro... All of my misfire problems have been ignition coil related.. I've changed out about 3, but I just recently picked up some low mileage Motorcrafts for $30, so I replaced them all!! It got rid of my slight miss at idle.
jstreet0204
939
Winston Salem, NC
Dec 13, 2006
#22
  • Dec 13, 2006
  • #22
Are there any mods done to this car? Going back through your posts it doesn't look like you have had it very long. Do you possibly have a timing adjuster on it. Timing adjusters can cause some bucking during light load like that. If your test don't work out, post back with all the mods if any that have been done to the car.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Dec 13, 2006
#23
  • Dec 13, 2006
  • #23
Smokeurhonda said:
Well call up your local dealer and see. Maybe there is an extended recall for PCM flashes or something like that.
There is none.
Kappa2006 said:
Yes, I followed some DC's and it directed me towards fuel and ignition tests. I just finished the MAF ones and they checked out ok. Now I'm going to do the fuel tests tonight (fuel pressure, injector balance test, injector resistance tests). and if I have time I'll so some tests on the coils. One thing I forgot to mention is that I found a ford TSB stating that some pcms need to be reprogrammed due to hesistation when accelerating. I kind of pushed this to the side since the hesitation is pretty bad, but if everything else checks out, I might have to look into pcm programming options.
Check this TSB out.. might not be your problem but it's worth a shot.
http://www.stangnet.com/images/stories/docs/sn95_TSBs/98-23-10.pdf
bgrd351
109
Jacksonville, Fl
Dec 13, 2006
#24
  • Dec 13, 2006
  • #24
svttech76: it is is interesting that that TSB you provided doesnt say to clean the MAF at all but instead to replace it. Does Ford not allow the cleaning or just not on this TSB?
Mike97gt
it doe snot
10,633
Dec 13, 2006
#25
  • Dec 13, 2006
  • #25
Ford has never suggested cleaning the MAF to us.. They want us to replace them. That does not mean it's a bad idea to clean them, it's just not ford suggested practice.
K
Kappa2006
36
#26
  • Dec 14, 2006
  • #26
Ok, the search continues. I did the injector balance test yesterday, each injector
lowered the starting fuel pressure the same amount. so no clogged injectors. I ohmed out each coil, no coil was over 6 K ohms resistance. The primary circuit resistances were all within spec. Hooked it up to an oscilliscope to monitor the coils while the car was running, nothing abnormal. Checked the maf readings again, according to a volumetric efficiency program I have, the efficiency of my intake and maf sensor is about 78-83%. This tue I'm going to put the car on a dyno and monitor EVERYTHING. This way I can make the car misfire and see if anything shows up. and I will look through that tsb you supplied me. Thanks for the help so far. I'll keep everyone posted.
Smokeurhonda
457
Maryland
Dec 14, 2006
#27
  • Dec 14, 2006
  • #27
Man, it's gotta be your pcm.
K
Kappa2006
36
#28
  • Dec 14, 2006
  • #28
Well I finally have some results here....or should I say, I finally found something thats off. Checked fuel pressures today while running. with the vacuum hose attatched to the fuel press. regulator, I got barely 32 psi. With the vacuum hose removed, I got 41 psi. So my regulator is working fine, but according to my trusty Haynes manual, I don't have enough fuel pressure. The specs I have are 35 psi at idle, vacuum hose attached, and 45-55 psi at idle vacuum hose removed. I did replace my fuel filter too. I know how to test the output of a fuel pump on a return fuel system, but I'm not sure on a returnless system. and for the record, the guy I bought this car from said he had it sitting for a few months. He claims he'd go out and start it up once in a while, but who knows. So there is a possibility its a fuel pump issue. anyone know how to test the max output of the fuel pump?
Smokeurhonda
457
Maryland
Dec 14, 2006
#29
  • Dec 14, 2006
  • #29
Well here are some numbers for comparison. I tested my fuel system a few months ago in an engine performance class. Here are some of the results. 02 Mustang GT, with bolt on's. Stock fuel delivery.
Idle: 28-30 psi,
2500rpm: 29psi,
wot rev:55psi.
I also have results from putting vacuum on the regulator.
0"Hg 40psi,
5"Hg 37psi,
10"Hg 35psi,
15"Hg 32 psi,
20"Hg 30 psi,
25"Hg 29psi.
I have absolutely no drivability issues what so ever. Sounds like your car is right in the ball park compared to mine. And remeber, the pcm alters the amount of pulseing current to the fuel pump. Mine operated @ 7.1 volts and about 2.4 amps at idle, and will go up as you add load to the engine. Hope this helps.
K
Kappa2006
36
#30
  • Dec 14, 2006
  • #30
that does help. everything seems to be the same except for my wot figure. mine definately didn't get up to 55 psi. i think the max i saw was 45. But I don't think its a fuel problem anymore. After thinking about it, if lacking fuel was causing the mis, it wouldn't pull normally at high rpms, when the fuel demand is higher than lower rpms. It would mis throughout the rpm range. Mine mostly does it at the lower rpms. I guess I gotta wait it out till I can get the car on the dyno, make the problem happen, and monitor every possible sensor on the car.
Smokeurhonda
457
Maryland
Dec 15, 2006
#31
  • Dec 15, 2006
  • #31
I mean, you've pretty much checked every sensor, or major component. I truely do beleive it is your pcm. But, it's good that you are actually taking the time to diagnose, instead of throwing parts at the car. Stay with it and you'll find the problem.
Mike97gt
it doe snot
10,633
Dec 15, 2006
#32
  • Dec 15, 2006
  • #32
I agree with you that it's not a lack of fuel issue, that would be more noticeable at high load/high rpm...
I would be looking more at maf contamination or a week COP
Sounds like you have access to scan equipment, what are you using?
K
Kappa2006
36
#33
  • Dec 16, 2006
  • #33
I've been using a snap on scan tool. Its been pretty helpful in checked sensors, but it won't let you monitor the ignition system, or misfire recognition. Basically useful for looking at PIDS. Anyways...
I hooked it up to an oscilliscope one more time and found some strange readings at my ignition coils. I saw a few of them spiking inconsistently. So I went out to Flood Ford and picked up three coils for 180 bucks. I took my best guess at which cylinders to install them in, and got lucky. The misfire is completely gone. So after all of this, it was weak cop's.
All in all, never go by the resistance values in your coils to determine whether they are bad or not. All of my readings were within specs, and it still turned out to be the coils.
Well at least I know every other component in my vehicle is working perectly haha.
Thanks for all of your help guys. Hopefully this thread can help other people out now. and now I can finally start modifying the car!
Brian
Brute03
232
#34
  • Dec 20, 2006
  • #34
this thread helps a ton man, i've been having the same problems and i did the new-coil-swap also and got no results but i didn't consider it could be multiple coils. oh, and all my coils were supposedly in spec so i guess i'll check e-bay for a cheap set
Mike97gt
it doe snot
10,633
Dec 21, 2006
#35
  • Dec 21, 2006
  • #35
Brian
GOOD JOB, glad you fixed it!! thanks for posting what you found after you fixed it. These threads are a lot more helpfull that way.
ab 281 gt
123
Irmo, SC
Dec 21, 2006
#36
  • Dec 21, 2006
  • #36
Told ya!! These ignition coils are a pain in the ass...
First Prev 2 of 2
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
