A basic free mod check list
  • Thread starter Thread starter nickg42oz
  • Start date Start date May 26, 2005
  • 3
First Prev 3 of 3
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
May 29, 2005
#41
  • May 29, 2005
  • #41
89sleeper said:
Sorry what I meant to say was to remember to bolt the bracket back on so snubber has a place to hit.
Are you talking about the metal bracket that goes over the top of the pumpkin that the dogbone was bolted up to from the bottom?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 30, 2005
#42
  • May 30, 2005
  • #42
93tealstang said:
Originally posted by jrichker:
"94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes."
I'm not completely sure its a direct "plug and play." I tried running a 70mm meter with original stock electronics and my car really ran rough. I swapped over my 55mm electronics (which is a no no) to the meter and the car ran smooth and seemed completely normal. I'm totally against swapping electronics but in this case it seemed to work. Seems to me like maybe the electronics from the 70mm meter are not to friendly with the ECU. Can you explain or prove that the meter is compatable and is a direct swap?
I used a 94-95 5.0 70 MM MAF. The injectors are the same, 19 LB. The engine is the same displacment and type, 5.0 pushrod v8 . I believe that I used the electronics that came with the 70 MM MAF, the part number on the MAF sensor is F2VF-12B579-A1A. It works fine for me & I see no reason it shouldn't work good on other 5.0 Mustangs.
04sleeper
2,674
14
89
Dallas, TX
May 30, 2005
#43
  • May 30, 2005
  • #43
Yes.
deadlast
495
Belmont, MA
May 30, 2005
#44
  • May 30, 2005
  • #44
how much weight should an o/r x save compared to the stock h?
N
NUTCASE
187
#45
  • May 31, 2005
  • #45
if you are counting with cats you could actually gain weight going from 2 1/4 pipe to 2 1/2 pipe
but that weight is not to be worried about becouse the larger pipes will make so much more power they will definatly pull thier own weight and then some
G
grrrrrrr
289
norfolk, VA
May 31, 2005
#46
  • May 31, 2005
  • #46
Shaved Body Hair/Take piss/remove penis/Clip toe nails
I am so in the 10's tommorow...
old_blue
1,783
282
124
Jun 13, 2005
#47
  • Jun 13, 2005
  • #47
subscribed
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Jun 14, 2005
#48
  • Jun 14, 2005
  • #48
i found a metal thing under the steering wheel, behind the plastic piece, it weighs a pound or so
darthcual
985
Arlington, TX
Jun 14, 2005
#49
  • Jun 14, 2005
  • #49
A good spark plug gapping/changing...oil change....rear end gear change...tranny fluid change. While not technically free these are things that need attention and can make a world of difference.
  • 3
First Prev 3 of 3
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Surging/stalling! problem or tune?
  • djj62478
  • Sunday at 1:53 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 11:37 PM
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
