  • SN95 4.6L Mustang Tech
A/C blowing Hot!
  • Thread starter Thread starter FastGT02
  • Start date Start date May 1, 2008
FastGT02
22
  • May 1, 2008
Hey guys. My A/C recently stopped blowing cold and now only blows hot air. I popped the hood and turned on the A/C noticed the A/C pulley was not moving then started clicking every 5 seconds while the pulley spun for a millisecond. I'm wondering what this could be before I get screwed by FORD?
Thanks guys.
rabidscoobie
616
12
48
College Station,TX
May 1, 2008
  • May 1, 2008
If the compressor is shutting on and off and blowing hot air,it most likely needs a recharge.
K
Kelso Gringo
14
  • May 1, 2008
Yes. First you can try injecting a can of freon from the auto store.
the98stang
2,408
Clovis, CA
May 2, 2008
  • May 2, 2008
Honestly it's best to take it to an AC shop. If you ran out of freon there is a leak somewhere, and refilling it with a recharge kit will only last so long before it all leaks out again...
Tripoli
208
Dallas, TX
May 2, 2008
  • May 2, 2008
Agreed. You can do a UV test yourself to try and find the leak, or you can just take it to someone.
The dryer is a pretty common culprit. Otherwise, likely a bad fitting or cracked line. I cracked a line once while working on something else under the hood. It really doesn't take much to damage them.
FastGT02
22
  • May 3, 2008
Thanks guys. Im just gonna take it to an A/C shop rather than Ford. I appreciate all your opinions.
2000fordstanggt
404
Westland, MI
May 3, 2008
  • May 3, 2008
could be the ac cycle switch. easy as pie to replace...and id bet thats what it is.
i just dont trust anyone, especially under my hood/working on my house.
try a search on it
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
  • dan50
  • Jul 18, 2026
dan50
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
