  • 1994 - 1995 Specific Tech
a/c blowing warm
  • Thread starter Thread starter Mustangless
  • Start date Start date May 6, 2007
Mustangless
903
home
May 6, 2007
  • May 6, 2007
I was going to try and fix my a/c today, but that did not work out. I bought a can of r134 with a gauge test from wally world. Put it on, started the car and turned air on max. The gauge did not move I put it on a car with working air and it did not move either, so I think the gauge is garbage.
Anyways, I have read where I can "jump" a wire to see if it needs freon. Does anyone have pictures, or can I get a little help on this part.
earleys94gt
1,223
Ashley, Ohio
May 6, 2007
  • May 6, 2007
Either the gueage is garbage, or you may have a leak in the system somewhere. Another possibility is what happened to me and your compressor is locked up...
drakesdad
961
Oregon OHIO
May 6, 2007
  • May 6, 2007
I have a question for you.....did you buy the guage that you screw in that penetrates the can..? If you did, you have to then unscrew it to let the 134 into the system........If you knew that ....then disregard.............my guage I bought from AZ did not read until I did that and then the system started to get cooler.....this was on the Crown Vic the short time I had it...?
Mustangless
903
home
May 6, 2007
  • May 6, 2007
the gauge went up a little, so I decided to fill it. It went to blue, which is where it was supposed to be but, the compressor is not spinning
Does that sound like I need a new one? Or could it still be something else?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 6, 2007
  • May 6, 2007
Im not sure what its called on a Mustang, but the pressure switch on my truck went out and the A/C would not come on because it thought that the system was empty and had no oil. See if you can jump it.
So when you turn the A/C on the clutch does not engage?
Mustangless
903
home
May 7, 2007
  • May 7, 2007
I guess the clutch is not engaging NM, it is.
I bought a can, with a hose on it that has a gauge attached to the hose. I don't think there is any type of screw on it. It went up alittle, but after filling it, it went up to where it was supposed to be.
H
HERS351
29
Central Florida
May 7, 2007
  • May 7, 2007
on the passenger side fire wall there is a round tank with some piping coming out that has a switch which plugs in at the top with two wires in it. that is your low refrigerant switch if you unplug that and put a wire in the plug to jump between wires it should bring the compressor on if it a low gas problem.
5.0 from 95
738
Emory, TX
May 8, 2007
  • May 8, 2007
I have had to change this out on my twice now. If this does turn your compressor on, go to the parts house and get the new switch. Don't leave the jumper on there for long because it will cause more damage. The switch is pretty cheap too.
Paul
Mustangless
903
home
May 8, 2007
  • May 8, 2007
:SNSign: that is what I needed to know.
Got the compressor spinning. I will have to check the pressure again tomorrow. Or does that mean I need a new lps?
Mustangless
903
home
May 9, 2007
#10
  • May 9, 2007
  • #10
I just filled it, but it only went to 15psi. When I started filling it, the psi was jumping between 10 and 35, then it settled at 15. How many cans does this usually take to fill? (this was an 18oz can)
it was leaking around the top for about the first 3 minutes so some probably escaped into the air.
Looks like autozones website says 7.00oz of a/c oil
Adam95GT
2,564
Burlington, NJ
May 9, 2007
#11
  • May 9, 2007
  • #11
oil isnt the same as the refrigrant... but it normally takes like 3-4 small cans IIRC
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
May 9, 2007
#12
  • May 9, 2007
  • #12
Are you selling your A/C parts?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 9, 2007
#13
  • May 9, 2007
  • #13
You need to remove the plug for the low pressure sensor and put a jumper wire in it's place. That will make the compressor run non-stop, and you fill it until you get to 35 or so.
Scott
Mustangless
903
home
May 12, 2007
#14
  • May 12, 2007
  • #14
What does it mean when the compressor cycles on and off?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 12, 2007
#15
  • May 12, 2007
  • #15
You have not jumped the low pressure switch.
Mustangless
903
home
May 12, 2007
#16
  • May 12, 2007
  • #16
yea, it is plugged in normal now. I was thinking it needed more r134, but with it is saying 125psi when it is jumped, or not jumped.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
