Hi All
Trying to figure out what is normal and what is the fix if needed.
I have a 1991 GT and I believe the components are all stock as the car has 32k miles. I replaced the plastic fan under the shroud earlier this year as it was cracked and ready to let go. Anyways, I have no cold AC (it was updated to the modern refer so I think it just needs a charge, but suspect it may have a leak) and when cruising around Houston at 90f ambient air temp the car will climb to the high end of the temp gauge while doing 70mph in 4th gear at 3k rpms. When I let off the gas for a bit it does come back down. The coolant is new, but it was filled and supplied in NJ last fall where I bought the car. Do I need a different coolant for Texas temps? where else am I likely to be having a temp issue? I find the footwells get quite warm even for a vert, and while I know that is somewhat normal, trying to determine if I have a temp problem or not.
Thanks
Gerard
Thanks
Gerard
