  • SN95 4.6L Mustang Tech
A/C charged...now a new problem
  • Thread starter Thread starter cobra2798
  • Start date Start date Jun 17, 2009
cobra2798
303
Clermont, Florida
Jun 17, 2009
  • Jun 17, 2009
So I took my A/C in to get looked at, could not find any leaks and the system checked out ok. They recharged the system and now it works great but there is a problem. With the A/C on the car is idling around 1,100-1,200rpm's, with it off it idles fine.....850-900rpm's. What is the problem here or is this normal?
jeremy canter
402
Orange County , NY
Jun 17, 2009
  • Jun 17, 2009
your car is fine it just needs the extra RPM TO HELP TURN THE ALT FOR YOUR BLOWER AND THE POWER TO TURN THE A/C > DON'T SWEAT IT > JUST ENJOY IT
cobra2798
303
Clermont, Florida
Jun 17, 2009
  • Jun 17, 2009
Great, thanks
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 17, 2009
  • Jun 17, 2009
As stated above....a couple hundred extra RPM is perfectly normal when the A/C is engauged.
Keep in mind, when your A/C comes on, it also kicks your electric fan into high gear. That draws additional current, which is why the engine speeds up to compensate.
bhuff30
6,037
35
129
Olathe KS
Jun 18, 2009
  • Jun 18, 2009
Really, you need to run a V8 at 1100-1200rpm just to turn the AC?
My 97 idles around 850-900with the AC on and only slightly lower with the AC off. Even my mom and sisters V6 mustangs don't break 1000rpm at idle with the AC on full blast. Your cobra may be programmed that way, but seems odd to me.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 18, 2009
  • Jun 18, 2009
You speak as though anyone should put any kind of faith into what the stock Tach says?
40oz
499
Minneapolis
Jun 19, 2009
  • Jun 19, 2009
for the record, I was noticing today that my 03 5-speed GT idles at pretty much the same rpm with AC on or off. I'm not going to go out and look, but it was under 1000 rpms, I'd guess ~750-800 or so. Point is that it shouldn't idle over 1000 when the car is warm, AC on or off, IMHO. But it's probably something stupid and cheap, whatever it is.
Don't ask me why I was looking at the tach for that today or why I checked this thread tonight, I'm just saying
the98stang
2,408
Clovis, CA
Jun 19, 2009
  • Jun 19, 2009
1200rpm with the AC on is OK....if you have a blower
1987stangman
684
24
  • Jun 20, 2009
+1 for that, I just replaced nearly everything under the hood A/C related and mine idles around 900 with the ac on. Even my Fox idles under 1000K with on.
I guess you need to look at the bigger picture. I'm gonna guess you took your car in because it was blowing warm, or just not keeping up? If it needed a re-charge, then u have a leak somewhere. Also, does the RPM drop when the compressor cycles (stops), and then goes up when it starts?
AdRock
521
South Texas
Jun 22, 2009
#10
  • Jun 22, 2009
  • #10
I have my idle set at 820 with the Diablo and it'll bump up to 1k when the A/C kicks on.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
squeak93
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
