My compressor is not turning on at all. When I check the connector that goes on the pump its not putting out anything. Does any know how to fix this?:SNSign:
Check your refrigerant level and the pressure switch on the condenser. If jumping the switch causes the compressor to run then either the switch is bad or the refrigerant is low.
I agree. YOu'd want to get some manifold gauges on the ports so when you jump the LPS on the accumulator, you can see if it's a refrigerant issue or electrical issue.
