A/C compresor squealing
  • Thread starter Thread starter rockyracoon
  • Start date Start date May 1, 2006
R
rockyracoon
874
27
49
margate NJ
May 1, 2006
  • May 1, 2006
is there a bearing in the front that can be swapped out.This is happning without the clutch being engaged.
D
Daggar
3,902
  • May 1, 2006
You can swap the entire clutch assembly. Good job it's squeeling when the compressor's not moving. At least you know it's not shaft bearing.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 2, 2006
  • May 2, 2006
The A/C clutch is about $100 new or you can buy a compressor from the junkyard with a working clutch for about $50. The puller is about $16 if you have to buy one, Autozone will rent you one for free.
The clutch hub is usually what fails, the rubber shock damper shears off from the steel hub and plate. The pulley turns, but the hub doesn't when you power up the A/C The hub comes off without much problem if you have the puller. You don’t have to do anything with the refrigerant (R12 or R134a), you can replace the clutch without draining and refilling the system.
D
Daggar
3,902
  • May 2, 2006
One other small side note:
When you pull the clutch, keep inmind that there is cleverly hidden snap ring deep inside of the A/C pulley. All too often I've seen folks standing infront of their cars, staring and scratching their heads with beatup knuckles, an out of shape pulley, and a hammer showing signs of excessive battle damage. I personally have not needed a puller on the half dozen or so, clutches I've changed to get them loose. Just remember the snap ring.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
