A/C Delete Pulley From Ford
Bugman.dave
320
Ottawa, Canada
I just installed the A/C delete idler pulley from ford. The pulley seems a bit loose and wobbles a bit. I loosened the bold that holds it on and retightened, but it still seems loose, or at least not as tight as the other idler pulleys.
Any ideas?
i dont know if this is the best idea but my idea is to leave it alone.
i remember mine being loose too and it has been fine. that must be the way they are made. (you do mean the whole pully seems to wobble right?)
if so that is how mine is too. it is fine ive had mine installed for 1 yr. so far. :nice:
Yes it's just the pulley. The bracket is fine. The pulley just does not seem to fit as well as the other idler pulleys. The same part is used on the F-150 and the parts guy at Ford is checking into it for me. Seems by your experience though it's the same as mine,....
I'll leave it until I hear different,...
Thanks
