a/c delete
  • Thread starter Thread starter 9350coupe
  • Start date Start date May 29, 2005
9350coupe
109
chicago
May 29, 2005
  • May 29, 2005
I'm going to delete my a/c. Would like some comments and concerns. just take pressure out of lines remove and put delete kit on? Or what?
thanks
jb89coupe
416
CT
May 29, 2005
  • May 29, 2005
More or less.. you may want to take your car somewhere and have your system discharged first. Then you'll need a fuel rail/ac disconnect tool to get all the lines apart. You have to pull your radiator to get to the condensor.. then yank everything out and throw the delete kit on. You'll lose about 20 lbs from the front of your car, gain no power, and be real hot in the summer . Which kit did you get?
Stang8URMPRT
1,100
Daytona Beach, FL
May 29, 2005
  • May 29, 2005
Yep, you can take out all the hoses, compressor (obviously), accumulator, drier, condensor (in front of the radiator)... take it all out baby
Scorcher2005
883
South Carolina
May 29, 2005
  • May 29, 2005
you dont need to take out the radiator to get the condensor out. Me and my buddy installed the whole a/c delete kit in auto shop in about and hour or so. The only thing was we had cheap plastic quick dissconnect tools and couldnt get them to work. We ended up fishing all the lines out, only had to cut one.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 29, 2005
  • May 29, 2005
Pretty easy to do. Get a A/C fuel line disconnect tool, and the rest is all gravy. You will need the Delete kit and and a new belt. I guess start pulling off all A/C components. Have it discharged as a shop first. Unbolt the P/S pressure line from the body, it will have to move some, then reattach. Really, not too much too it.
Stang8URMPRT
1,100
Daytona Beach, FL
May 29, 2005
  • May 29, 2005
If you DO have it discharged at a shop, make sure they PAY YOU FOR THE FREON! All they will do is take your freon, and sell it to someone else. If I were you, I'd open a line and let it drain out. Who the f uck cares about it going into the air. How many of us have dumped our coolant or oil down the drain. Gimme a break.
Scorcher2005
883
South Carolina
May 29, 2005
  • May 29, 2005
to drain mine all i did was unscrew the 2 caps in the parking lot and press in the valve. no more freon
Aliate X
602
Rockland NY
May 30, 2005
  • May 30, 2005
I thought AC delete was 60 lbs?
jb89coupe
416
CT
May 30, 2005
  • May 30, 2005
How did you get the consdenser out with the radiator in place?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 30, 2005
#10
  • May 30, 2005
  • #10
My thoughts exactly...
blown93feature
151
living on edge like the motor
May 30, 2005
#11
  • May 30, 2005
  • #11
I didn't take the radiator out either. I just unbolted it and pulled it down through the bottom after I took the 4 or 5 bolts out that support the front facia.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
K
WTB Looking for Trade! 1990 Chevrolet c1500 Silverado for Cobra
  • kingcron32
  • Oct 20, 2026
  • Want to Buy
Want to Buy Oct 20, 2026
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
