A.C. Help
How did you ascertain that you have the proper amount of refrigerant? That's tough to do if the clutch won't engage.
If the LPCS has 12 volts in and out, go check your WOT relay. The wiring is prone to vulcanizing and it can keep the clutch from engaging.
Good luck.
