A/C makes my car run REALLY slow.
dmontzsta
111
SoCal
I dont know why it does this, I have never had any other car do this. When my A/C is on the car is a complete dog. I can punch it and it sounds strong, but it just does not move like it does when it is off. It also is making a sound like a supercharger when it is on. The compressor is pretty loud at high rpm. My car would probably lose to a civic with the A/C on.
Any ideas?
04gtdrop said:
I've heard that you lose 20% of your power when the a/c is on. But its supposed to cut off at WOT.....maybe someone else with more knowledge will chime in.
that explains why when i boot it, the a/c stops blowing cold, thanks man
oh and sorry for taking over your thread, you can have it back now its used anyway lol
Si
P.S do you actually lose 20% then??
Something I noticed after driving my 99 which had steeda UDP's, and
my 04 which doesnt have them yet. The air conditioner wont put as
big of a strain on the engine, seems like 50% less hp draw to me w/UDP's.
Anyone else notice that?
svttech76 said:
with your a/c making that much noise and power loss I think you have a seized or partially seized up compressor..
So with the A/C off you don't have the noise you described but with the a/c engaged you do? if so then buy a new compressor.
That is correct. Sometimes it does not feel that cold either, dont know if it is cause of the 100 degree temps outside though. I dont know if it is normal, but at an idle with the A/C on, it will kick my rpm up a little, then it backs down, you can hear the compressor kicking on and off.
The problem with the A/C is that it tends to heat soak the engine if you run it for a while in traffic. All the hot air from the condensor mixes with the hot air from the radiator and heatsoaks your engine bay and your car ends up a total dog.
Doesn't matter if it kicks out at WOT either, you lose a LOT of power.
If i sit in traffic for 20 mins on a hot 90+ degree day and then get to an area when i can floor it, my car is such a dog. It will bog off the line and then WOT feels like 1/4 throttle on a normal day.
I never notice such a dramatic loss in any other vehicles.
My A/C is ice cold though. I love it
I agree with Mike your A/C compressor is probably bad
and needs to be replaced.My A/C compressor on my car
was not blowing out any cold air.I had my mechanic look
at it and it turned out that my seals in my A/C compressor had two holes in them and the clutches were
bad.I had to recharge the system too.I ended up installing a brand new Motorcraft A/C compressor and recharging the system and the problem was gone.
