a/c problem
93GtMustang50
63
Orlando
I can not switch between max a/c, norm a/c, vent, floor, mix and defrost. Regardless of which selection i put it on, it goes to floor selection. It seems to be frozen there. the A/C works when its turned to cool, the heat works when it put to heat. any ideas?
There is a vacuum leak you need to hunt down. Likely in the engine bay somewhere but could be under the dash. Just follow lines from your HVAC box. Once you find the leak it will work again.
Most systems when there is no vacuum default to defrost. I would assume these cars are the same. If they are you either have a pinched vacuum hose or a bad control. An open or leaking vacuum hose on almost every car I've ever seen will make it move to defrost. Just my .02
