  • 1994 - 1995 Specific Tech
a/c question
  • Thread starter Thread starter T-Town95GT
  • Start date Start date Jul 24, 2004
T
T-Town95GT
9
Tuscaloosa Al
Jul 24, 2004
  • Jul 24, 2004
My a/c clutch will not come on. It is full of R134A. If i jump the low pressure switch the clutch will not kick in. I can jump the clutch straight to the battery and the clutch will kick on and the a/c will cool fine.
Any suggestions?
sweet58
  • Aug 13, 2004
A/C Compressor not kicking in ANSWER!!
My buddy had the same problem that his A/C was not kicking in. So I checked all the two pressure switch (the one on the condersor and the one on the A/C steel line near the front passenger side of the car.) I put on the A/C in the car and checked that I had voltage with my test light at the plug on the compressor and there was.....BUT if the test light in NOT the same brightness as if u touched the test light straight to the battery..then u have a pressure switch that is bad. The pressure switch that was bad on my friends 95 5.0L was the one on the condenser near the passenger firewall. Also u do not need to empty the A/C system to change this switch...just unscrew it from the condenser and u will hear a little ppsstt..of freon kinda like when u unscrew the nozzle off of a propane torch.....BLa bla bla...if u need more detailed info, just reply to my reply and I will happy to go into specific deatails such as wire colors and jumpers etc...necessary to test the switchs....but I am sure most of u guys out there should be able to figure it out
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Saturday at 9:20 AM
Dawry Ramos
D
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
N ot New
  • TNmach1
  • Sep 18, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 18, 2026
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
