A cluck when I decellerate... ?
  • Thread starter Thread starter Cobra1894
  • Start date Start date Aug 7, 2005
Cobra1894
196
Broken Arrow, OK
Aug 7, 2005
  • Aug 7, 2005
I just replaced my rear end with a used one. I replaced the axle bearings, axles, Rear diff cover, and the Ring & Pinion looked good. I had a problem with the tailshaft seal leaking, But I have since replace it. I think its holding up. However I am getting a cluck when I go to shift at high RPM (4K+) and occassionally I get a vibration... The vibration will come and go, but the cluck is kinda common...Something with the drivetrain, but Im not sure what to check. Ideas????
D
DJFox
36
  • Aug 7, 2005
i had the exact same thing, a clunk under the under the car upon acceleration and then it would happen again once i let of the gas. It turned out to be the throw-out bearing. My only problem now is that I will wear out a throw out bearing in about 8 months with normal driving
Cobra1894
196
Broken Arrow, OK
Aug 7, 2005
  • Aug 7, 2005
Hmmm... I noticed a ball bearing in the bell housing.... I replaced my clutch about a year ago with new bearings... Is this common amoung Stang owners? Just a king cobra clutch... I also have a wierd crakling sound coming form the clutch area now. How would the throw out bearing cause the clunck?
HISSIN50
34
129
Aug 7, 2005
  • Aug 7, 2005
Do you have a chicken in the trunk? It will cluck.
Have you inspected your U-joints? If they have slop, the will make noise as the DS is loaded and unloaded (like as happens when you are accelerating and then hit the clutch). And worn U-joints can allow excessive run-out (ergo vibration).
Good luck.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
