a few problems im not sure about
65fastback2+2
1,229
Louisville, KY
#1, there is a vibrating from the car that peaks at 50 mph and goes away about 73mph. I know its coming from the back, and I think the back left. When I had it up on a jack and ran it, I noticed the wheel making significant movement left to right looking at the back of the car. Could this be the cause of the noise? Its not a solid vibration, but a vrmmmm...vrmmm....vrmmmmmm, pulsating about every 2 seconds. It drive me nuts cause it makes the trim pieces around the c4 shifter squeek. My dad has he thinks its a wheel bearing going out.
#2, the car leans. Looking it at from the back it leans alot to the right. its alot cause everyone notices it and asks whats wrong with it. And if I had to say, it leans to the back, trying to pinpoint an area here for ya. Is it a going out shock, weak spring, etc???
Thanks
for the sagging, check your leaf spring mounts, under the flooboard where they connect to the body, they are known to give over time and your car wont sit right.
Vibration could be a wheel bearing, or bent wheel.
