? about welding
  • Thread starter Thread starter stangman16
  • Start date Start date Apr 1, 2007
stangman16
640
San Antonio, TX
Apr 1, 2007
  • Apr 1, 2007
I just got a welder and I'm needing to find some scrap metal to practice on, before tearing up the '66. Does anyone know what gauge the sheetmetal is for the cowl vents, and quarter panels?
Other than going to the local pick 'n pull, would a hardware store have the gauge metal I need to practice with?
thanks!
BlackGMC
247
  • Apr 1, 2007
I think all the metal your talking about is 18 gauge. The hardware store might have it but it will cost, it would be cheaper to find a metal distributor around you.
351w_swap
263
  • Apr 1, 2007
Get something more like 12 or 14 ga to practice on first, welding is not very easy and learning to weld on thin stuff is even harder.
D
danny clemens
728
  • Apr 1, 2007
I think the metal in a lot of cars is about .031". Maybe you can go to a bodyshop and they might have some wrecked panels that they would give you. Maybe some metal out of some scrap appliances.
mtaqua
345
  • Apr 1, 2007
i went to body shop and the owner let me go through his scraps. i'd try that prior to buying any metal. only problem is it will be thinner than the old metal. i would think it will be harder to weld new car metal as it seems to be much thinner.
xoxbxfx
3,959
Southlake, TX
Apr 2, 2007
  • Apr 2, 2007
I would use 18-20ga steel. Make sure you dont get galvanized steel. When welding anything like that, just do lots of tacks..never weld a full bead on a bodypanel
R
RUSTYNUT
128
PDX
Apr 2, 2007
  • Apr 2, 2007
You should try a local u-pull - it and get some cheap body parts. one foender can give lots of practice.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Apr 2, 2007
  • Apr 2, 2007
Depending on the quarter panel vendor, replacements are only 19 to 21 gauge. You will need to use shielding gas. Same for cowl panels.
BlackGMC
247
  • Apr 2, 2007
Since you will be welding the thin stuff, get some .025 wire, and some gas. That will make it easier.
10secgoal
2,801
San Diego
Apr 2, 2007
#10
  • Apr 2, 2007
  • #10
You can also go to your local welding store and find a gel you can put the metal that keeps it from warping. It stops the heat from spreading.
Soaring1
Banned
Jan 3, 2003
144
Texas
Apr 2, 2007
#11
  • Apr 2, 2007
  • #11
metal
Go to a computer store and see if they will give you the old hulls from the old puters that were traded in. That metal on the outside of the computers will give you a good feel for welding thin metal without burning through.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
WTB/Trade Looking for a T-Top Hatch. Possible convertible trade? (Rhode Island)
  • 7upper
  • Mar 18, 2025
Fox Body Mustangs For Sale (1979-93) Mar 18, 2025
7upper
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
