  • SN95 4.6L Mustang Tech
ABS Light
  • Thread starter Thread starter stangboy0614
  • Start date Start date Sep 2, 2004
stangboy0614
Chicago
Sep 2, 2004
  • Sep 2, 2004
First off I would like to say hi, since I am new to this forum. Anyway I had something really weird happen to me. I was driving my 2000 Mustang Gt with 31,500 miles on it when the ABS light came on. Seconds after that the car sputtered and died. I put the car in park and started it right back up. As I was driving back home the ABS light came on as well as the right turn signal and they both stayed on. The car drove fine after the time it died. I think the rough idle maybe due to some bad gas, but thats just a guess. However, now that the ABS and turn signal light are on the right front turn signal does not work and neither does that head light. I thought possibly fuses but those look ok. Is there any insight to what may have caused all of these things to happen at the same time? How would I go about fixing this? Thanks for any help in advance.
M
MaxMustang
53
  • Sep 2, 2004
bad alternator, bad cell in battery
stangboy0614
Chicago
Sep 2, 2004
  • Sep 2, 2004
Here is an update to what is going on with this problem. I ran the car during my lunch break and the ABS light did not go on as well as the turn signal light. I tried the turn signal and it works fine. However when I turn the headlights on the ABS light and turn signal light goes on. At this point the turn signal doesnt work and the headlight doesnt work. Is it possible that a burned out headlight could cause this to happen? I have not taken a look at the relays under the hood to see if any of these are burned out. Any help would be great.
Cobra Jay
889
Motor City
Sep 2, 2004
  • Sep 2, 2004
Try clearing the memory. It's worth a shot. Disconnect the postiive battery cable. Turn the key on and off 3 times. Leave battery disconnected for 30 seconds. Reconnect and see what happens.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Sep 2, 2004
  • Sep 2, 2004
You may have a bad relay or the headlight switch may be bad. Sounds like something is shorting somewhere.
H
huesmann
332
  • Sep 3, 2004
Short circuit.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
