You need to hook up a set of guages and look at liquid and suction pressures. If the orifice tube is blocked, suction pressure will be low and pressure line may be high (or not). Also you need to verify that the blend-air door is moving and that it isn't stuck in a partially-open mode where some of the cabin air goes through the heater core making it look like the A/C is not working properly.
If compressor is kicking on and off, it doesn't sound like a plugged orifice tube. Is the drier cold to the touch?
