Ac problems still
  • Thread starter Thread starter chr1s11575stang
  • Start date Start date Sep 7, 2007
chr1s11575stang
64
Orlando, Fl
Sep 7, 2007
  • Sep 7, 2007
Ok I got the ac working and its cold as heck. But when I accelerate it gets warm. Whats causing this and what can I do to fix it?
1990 Gt
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 7, 2007
  • Sep 7, 2007
I had this problem with a 97 Cobra. There was a switch on the evaporator on the firewall. It unthreaded by hand...(no freeon came out). I put another used one on and it fixed it. I do not know if the older foxes have this switch or not. Just my .02
chr1s11575stang
64
Orlando, Fl
Sep 7, 2007
  • Sep 7, 2007
Is there anyone that can help me with this please? Svt made a suggestion but im trying to figure it out. Will it work for a 90 gt
SVT32VDOHC
3,501
28
119
Motor City
Sep 7, 2007
  • Sep 7, 2007
It is located on the firewall...passenger side behind the strut tower. It is a black tubular canister. with the ac lines going to it.
chr1s11575stang
64
Orlando, Fl
Sep 7, 2007
  • Sep 7, 2007
ok so is it the low pressure switch? where it plugs into?
HISSIN50
34
129
Sep 7, 2007
  • Sep 7, 2007
At WOT (2.71 TPS volts over the ratcheted baseline), the WOT kicks the compressor off. The AC can blow hot for a short period.
Otherwise, if not hitting WOT and the AC is warm:
A low charge can cause the compressor to kick off once it has engaged for a few seconds (the low side is pulled down below the LPCS threshold).
Put a set of manifold gauges on and see what it's doing. Otherwise you will be guessing at what's wrong. If your low side pressure is adequate but the compressor cycles off, that's a time to consider the LPCS being bad. Otherwise, the switch might be fine and you just dont have enough refrigerant in the system.
Good luck.
chr1s11575stang
64
Orlando, Fl
Sep 7, 2007
  • Sep 7, 2007
ok the compressor runs constantly while the air is on. it doesn t kick in and out it goes normal. The valve on the firewall seems to be working properly. also i checked the freon and there is plenty. Any other suggestions?
HISSIN50
34
129
Sep 8, 2007
  • Sep 8, 2007
YOur compressor never cycled while you tested it (at say 2500 RPM)? There's a considerable volume of refrigerant in there if that is so.
If that's so, you might have an issue with the vents, where the AC is being dumped out the defroster vents when manifold vac drops significantly.
cjones
1,561
Avondale, AZ
Sep 8, 2007
  • Sep 8, 2007
what were the gauge readings for the A/C??
strtrcr50
Previously from Dirty Jerzey exit 7a
Sep 8, 2007
#10
  • Sep 8, 2007
  • #10
It's possible you have overcharged it and the belt is slipping when the rpms come up.
Dachipsta
35
12
#11
  • Sep 8, 2007
  • #11
The only way to really be able to tell what is happening here is to get some gauges on the thing. Otherwise, you will be doing nothing but guessing and by adding more gas to it, you have a real possibility of overcharging the system and blowing out a seal in the compressor among other things.
As the rpms climb, the low pressure side of the system has a tendency to drop and if its undercharged, the drop in pressure will be more significant. That could be the reason why under acceleration, the compressor is dropping in and out. A restricted orifice tube and screen can cause this pressure drop as well but will be accompanied by a rise in hi side pressure as well. This is why its critical that a set of gauges be placed on the system so a correct diagnosis can be made. Even by attempting to diagnose the system's operation by using only a low side gauge is asking for trouble. What can look to be a low charge could very well be a restricted system without the knowledge of what the high side of the system is doing.
Also, you said the refrig. level was checked and is ok. How do you know this? The only way to truly tell is to pull the refr. charge, evac and weigh in the required amount. This eliminates the guessing and will also tell you if the system componants are operating as they should....ie. restricted orifice tube/screen, compressor valves...ect.
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
