accesory delay shutoff?
  • Thread starter Thread starter rickman
  • Start date Start date Apr 3, 2005
rickman
49
des moines
Apr 3, 2005
  • Apr 3, 2005
Help! how does one switch the accesory delay on and off? I want to try the window features w/the pod/key on the active anti theft...
R
ROCKET-2300
23
  • Apr 3, 2005
There is no way to turn off the accessory delay feature.
If you have the key in the off position and try the "opening all windows"
feature (on page 65 of the owners manual), and it doesn't work,
then take the car to the dealer to have it looked at.
Previous posts were about this issue, and the dealer can fix it.
Hatchman
86
Pensacola
May 15, 2005
  • May 15, 2005
I'm having the same problem, anybody know a fix without taking it back to the dealer? Can a Diablo enable/disable it?
C
ctfordguy
39
  • May 15, 2005
I had my car in for the global windows open/closing. Ford put out a bulletin in April stating that cars built after Jan 3 were not equipped with the feature.
As for the accessory delay on/off, there is a relay in the fuse panel, pulling the relay should disable the feature, although I have not tried as I like having the radio on until I get out of the car.
BrewTownVert
47
Milwaukee, WI
May 15, 2005
  • May 15, 2005
so if my car has the auto-window-down feature, it was built before 1/3? when did they start producing convertibles? cuz mine works.
F
Ford Tech
  • May 15, 2005
global open/close
Yeah, I just got my GT on 5-12 and found out that the global open/close feature was disabled after Jan 3rd production (ssm from Ford). I think the smart junction box is the same unit (this is where the windows are controlled). If the modules are the same, the feature may be able to be reactivated using "as Built" data from an older car "flash programmed" into a newer car using Ford's WDS scan tool. I am going to research this and see if it can be done. I was pretty disappointed as this was the only reason I ordered the active anti-theft system.
scarypat2001
14
  • May 15, 2005
Just a question...
Although it's sad that Ford decided the disable the keyfob window up/down function (I really thought this was cool), it was probably done for a reason...
Didn't I read from a previous post (before the big crash) that a few of the owners ended up finding their cars with the windows down in the morning, and one of the guys actually had his car full of snow?
Reactivating a feature that was "cancelled" due to some issue might not be a wise move...
F
Ford Tech
  • May 15, 2005
Yeah there might be a reason for the function to have been cancelled. Will call Ford's tech hotline and see if they can give me some insight why this was done. It may be due to a RF interference problem rolling the windows up/down by accident. If this is the case, might be better to leave it alone.
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
