I just noticed that my right side exhaust (the muffler and tip) are slightly lower than my left side. I'm not sure why. Is there a way to adjust the height of it to raise it back up so it's in line with the left exhaust?
start with the clamp at the muffler. loosen it and try to adjust. if you cant get it perfect, loosen the clamp at the h-pipe connection and slightly rotate the pipe from there. it will take some trial and error, but it should work.
it is best if you have someone watch how the muffler is moving as you adjust the pipes.
