  • 1994 - 1995 Specific Tech
Adjusting Timing
  • Thread starter Thread starter law
  • Start date Start date Nov 24, 2005
L
law
290
  • Nov 24, 2005
I did a search and did not come up with what I needed to know. I have two questions concerning timing. First, I checked my timing and if I did it correctly than the timing marks on my balancer compared to the stationary mark if you were looking at it from front of engine is as follows: the base timing mark on the balancer is far left from the stationary mark. So does that mean that my timing is advanced. I think it was advanced to like twenty* or so. My balancer slipped and I had to replace but I just had not checked the timing yet. Second, what tool and how do I turn the distributor so I can set it back to base timing. Clockwise is for advancing and CCW is for retarding correct? Thanks for any clarification. Happy T-day!
HISSIN50
34
129
Nov 24, 2005
  • Nov 24, 2005
What do you mean by the 'base timing mark'? Do you mean the 10 or 12* you want to run, or do you mean 0* (TDC)?
If the former, it does sound like you were advanced a good little bit.
I use a 1/4" socket, with a Universal swivel, and two long extensions, to loosen the dizzy. They do make special wrenches for this - I should get one.
You probably already saw it, but here is an article on doing timing.
Good luck bud, and happy T-day back atcha'.
RIO5.0
6,892
N.H.
Nov 24, 2005
  • Nov 24, 2005
If you can read a 20, then its adv...as it only goes to 10 or so the other way...
I happen to use a swivel adapter/small socket right at the end to snake in there...you only need to crack it a tad to move the dizzy..you want some resistance to turn it so it don't go all over the place...
Make sure its warm when you set it, and yank the spout...
The TOP of the tab is what your shooting at..
L
law
290
  • Nov 24, 2005
Yeah 10-12* mark, sorry. Alright cool, then I am on the right path. I will probably just pick up the tool to make it easier for me. So is it CW to advance and CCW to retard, right? Thanks guys! Enjoy the food, I know I will.
legalize420
1,541
South Florida
Nov 24, 2005
  • Nov 24, 2005
law said:
So is it CW to advance and CCW to retard, right? .
yes
L
law
290
  • Nov 24, 2005
Thanks!
HISSIN50
34
129
Nov 24, 2005
  • Nov 24, 2005
I will also say this. If using an adjustable light (where it has a dial knob on it to set the advance), make sure you have the knob set to 0 when using the method you are using.
Good luck.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 24, 2005
  • Nov 24, 2005
ive always been confused about this, whitch mark do i use to set timing
red blue or green
HISSIN50
34
129
Nov 24, 2005
  • Nov 24, 2005
I use the red.
RIO5.0
6,892
N.H.
Nov 24, 2005
#10
  • Nov 24, 2005
  • #10
If you sand the grunge away on the top, you'll see the word "time" embossed right into the timing tab...So yes, Red's the winner...
legalize420
1,541
South Florida
Nov 24, 2005
#11
  • Nov 24, 2005
  • #11
:Word: red
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 24, 2005
#12
  • Nov 24, 2005
  • #12
I use the opal frost tab ......
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
