Will a alumn driveline from a areostar work in our fox stangs? someone told me one would. if so or not why wont it work in a stang? also what year do of areostar do i need to look for? peace
From what I've heard it is only the from the aerostars with AWD and you have to use a different yoke, I'm sure if you search here you can find the part number or someone else will chime in
you can use the 2wd one if you want to pay to have it shortened. The one i used the input shaft was fine but i had to change the rear u joint an use the mustang rear flange.
