Ok... I think every time I have posted I have problems with this dang stang!! LoL
Ok here we go I am going to give list of symptoms hopefully I can get some good answers im sick of spending money and nothing being fixed hehe
-First What has been replaced through visits at the shop....
Clutch,flywheel,TOB
New Fuel Injectors, washers, orings, and also fuel regulator
sparkplugs, wires, cap, and rotor
The main motor has been completely re-done but not at a shop
-Here the problems from start to finish
-The car runs like garbage!! Thats all..
I've been having problems with acceleration.. HP Loss.. Spark knock high alternator charge, even pulsating amp needle
-My RPM is sitting at 1k an cannot get it to lower
-My car runs rich and lean with gas..
the car was scanned and the gas going per injector is not constant it fluxuates quite a bit.. not sure of the exact numbers but I want to say between 2 - 5lbs of pressure..
-Im getting maybe 4-10miles per gallon it does depend on the car
-When I first start the car I have to give it more gas when pulling into traffic or it will fall on its face a little bit..
When the car is warm.. Its hard to start I have to keep giving it gas or it will stall until i get the car over 20MPH an it will stay running
-I have a spark knock in the first cylinder when I take the wire out it stops.. but when I get on it I hear a ticking sound..
-I changed the plugs and wires doesnt seem to be helping that..
-WHEN I GET ON THE ACCELERATOR HARD.. the car sounds louder then its moving seems to be held back..
The timing is fine for ignition
I know my EGR is screwed it is not functioning as I have capped it off on both sides so there is no leaks
-These are the main issues.. Im so confused right now I just want to buy a moped! haha
Waiting for some great answers!
Clutch,flywheel,TOB
