AIC trouble
BigPonyMan
47
South Carolina
IAC trouble
So my idle air control valve is on its way out again. I was wondering if there was a place I could get a replacement and fix this problem myself. How hard is it to install. I had the dealer replace the last one under warranty and the job only lasted a year and a half maybe 2 at the most. Any info is appreciated.
Um, i think that autozone sells them :shrug: . make sure it comes with a gasket. Its SUPER easy to remove the IAC. Mine hasnt went out but we removed it when we changed plenums (obviously). I think they are around $50.
Also clean the old gasket off of the plenum.
http://www.parts.com/partlocator/in...ake=10&model=Mustang gt&year=2001&catalogid=1
I prefer OEM on most newer (replacement) emission and fuel injection parts. OEM usually supplies upgraded or "improved" designs a lot faster than most of the part stores.
i paid $37 for a new IAC last night at advance auto parts... it even came with a 1 year warranty. it took me about 2 minutes to change, very easy. i can upload pics if you dont know where the IAC is located at.. it is just 2 bolts. just let me know.
BigPonyMan said:
So as for my other Q, is it normal fro the IAC valve to only last for a couple of years and then die?
On the Stang, I wouldn't think so. The one on my other Ford lasted 11 years.
Edit: As for spraying it with carb cleaner... You stand a good chance of ruining the internals with a harsh cleaner (been there done that). However they do make carb cleaners that are sensor safe. So if you choose to clean vs. replace just use a cleaner that is sensor safe.
as i promised.....
BigPonyMan said:
No biggie, just whenever you can is fine with me.
here are pics. there is 2 bolts. very simple operation. make sure u get the old gasket off.
Yea mine doesn't look like that unfortunately, but I found it and put the IAC on no problems so thanks anyway. Now about that little black thing that spins on the top of it, what does that do? I've turned it while the car is on and nothing happened at all.
