air bag light blinking
  • Thread starter Thread starter low5.0
  • Start date Start date Apr 21, 2005
L
low5.0
54
las vegas
Apr 21, 2005
  • Apr 21, 2005
I just changed my radiator and when I started it the air bag light started blinking. It blinks twice pauses then blinks three times and repeats. Does anyone know what this is as it is bothersome and scary.
mustangjoe87
364
Harrison Twp., Michigan
Apr 22, 2005
  • Apr 22, 2005
there is a sensor up front by the radiator that you may have damaged, check the codes and it will specify
L
low5.0
54
las vegas
Apr 22, 2005
  • Apr 22, 2005
thanx alot
vristang
4,933
101
124
Seattle
Apr 22, 2005
  • Apr 22, 2005
The codes will tell you what it is. I would guess that one of the front sensors was unplugged during the rad. install.
Don't be too afraid, the air bags system usually disables when something goes wrong, meaning the bags should never go off when your just cruising along. But they may not go off when you need them either.
mustangjoe87
364
Apr 24, 2005
  • Apr 24, 2005
if the light is on the system is disabled because of malfunction ie. could be a unplugged sensor.
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
M
Electrical Right Blinker will turn on but not Flash
  • Mayotic
  • Jul 17, 2024
Fox 5.0 Mustang Tech Jul 17, 2024
Mustang5L5
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
F
Need some help with LED conversion on 04 GT
  • FATTS_DC
  • Feb 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 24, 2025
stormsedge
