AIR BAG LIGHT
  • Thread starter Thread starter HOTRODDAVE
  • Start date Start date Aug 19, 2006
H
HOTRODDAVE
  • Aug 19, 2006
HI THERE
I OWN A 92 LX 5.0
I HAVE AN AIRBAG LIGHT THAT ALLWAYS FLASHES.I HAVE CALLED FORD AND THEY SAY IT MAY BE SOMETHING TO DO WITH THE SEAT BELTS..IT MAY BE FLASHING A 2 THEN 7.I AM NOT POSATIVE ABOUT THAT. THE CAR IS A SHOW CAR AND I REALLEY DO NOT WANT TO BRING IT TO SOME FORD DEALER THAT I DO NOT KNOW...ANY HELP WOULD BE GREAT THANKS DAVE
RUNINAGT
237
CHARLESTON S.C.
Aug 19, 2006
  • Aug 19, 2006
Mine flashes as well. We checked it @ our shop and it was a power issue. I think we needed to check the fuse but it was somewhere in the dash (in-line fuse???)
HISSIN50
34
129
Aug 19, 2006
  • Aug 19, 2006
This info might be useful. Courtesy of S&2B's.
Good luck.
bennettracing
280
Ava, MO
Aug 19, 2006
  • Aug 19, 2006
I recently had the same problem with my '90 LX, I'm not a fan of airbags, so I removed the light from the dash when cleaning the cluster. As a result of this, a buzzer started from behind the dash as a replacement for the light. As I dont' care if airbags work or not, I found out the airbag computer is a blue electrical box mounted behind the A/C controls...probably have to remove center console to access. I carefully taped up the connectors to ensure no contacts between pins and have had no problems....unless I needed the airbag, and then I'm ****ed...
The start of my whole problem was some genious before me decided the backup power supply mounted above the glovebox was optional...
stang&2Birds
2,091
New England. :-) CT/MA
Aug 20, 2006
  • Aug 20, 2006
HOTRODDAVE: HI! COOL! WHERE DID YOU FIND THE 1950's TELETYPE?? IT MUST SUCK TRYING TO SURF THE WEB ON A TELETYPE. WHET DO YOU DO TO SEE PICTURES? MAYBE IT'S TIME TOP STEP UP TO THE 80's AND GET A NEW FANGLED DEVICE - IT'S CALLED A "CRT". THESE NEW FANGLED DEVICES EVEN HAVE A BRAND NEW THING CALLED lower case. MAYBE AFTER YOU GET ONE OF THESE NEW FANGLED DEVICES, YOU MIGHT BE ABLE TO POST ON THE FORUMS?
BTW: 27 ISN'T A VALID CODE.
stang&2Birds
2,091
Aug 20, 2006
  • Aug 20, 2006
RUNINAGT: What's the code?
Most of the time it's the clock-spring. That's often shown at a code of "driver's side air bag has a high resistance". If your horn and cruise control don't work, that's another good sign that it's the clock-spring.
H
HOTRODDAVE
  • Aug 20, 2006
`HI COOL LEARN TO SPELL
BTW: 27 ISN'T A VALID CODE.[/QUOTE
MAYBE YOU SHOULD PAY MORE ATTENTION TO YOUR SPELLING AND NOT WORRY ABOUT THE PRINT TYPE..GOOD IDEA....
Killer50stang
632
  • Aug 20, 2006
If you dont' really care about it, pull the plug behind the cluster.
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
Old guy new to Forum.
  • 08shelby GT500
  • Jun 15, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 15, 2026
LILCBRA
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • dan50
  • Jul 18, 2026
dan50
