  • SN95 4.6L Mustang Tech
Air Condition System
  • Thread starter Thread starter dave_id
  • Start date Start date Mar 14, 2007
D
dave_id
44
  • Mar 14, 2007
My a/c don't blow cold air. heater works fine, but I dont need that in this starting to get 90 degree heat. It doesnt even cycle the idle. How do I tell if the compressor is busted?? And where do i start? Thanks a lot
:SNSign:
Twista
510
@ the z00 in chicago
Mar 14, 2007
  • Mar 14, 2007
Recharge it with feon? Autozone has the kits i think to recharge it for cheap.
DUNNO, BUT MAYBE
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Mar 14, 2007
  • Mar 14, 2007
it may be low on refrigirant, but if it is low then there might be a leak
D
dave_id
44
  • Mar 14, 2007
The thing is, it isnt cycling, if it was low (from what I've read) it would be cycling
I think the cycling switch is busted, anybody have a picture or a description?? Thanks
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 14, 2007
  • Mar 14, 2007
If the refridgerant is low it wouldn't cycle. Buy a pressure tester to see if it is low. They are not expensive.
D
dave_id
44
  • Mar 14, 2007
well there was no refridgant, so i put some in, it has a leak, but it wont cycle on either. So my next guess is the switch
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 14, 2007
  • Mar 14, 2007
Once the A/C system is empty it will not cycle at all. If it is low it will short cycle..
There could be other electrical reasons why the a/c will not turn on that you need to check..
First thing you can do is check the a/c charge level and if it's ok and it still don't run the compressor then you have a electrical problem. First thing I do from there is pull the connector from the low side cycling switch and short the connector with a paperclip on the harness end and see if it turns the compressor on.. check that then get back to us
D
dave_id
44
  • Mar 15, 2007
I pulled the switch and just put a new one on and nothing happened, I guess I should just try to short it. But I'm away from my car since im going to frisco for 3 days.
I checked the fuses and they're fine. The crap still dont go!
Mike97gt
it doe snot
10,633
Mar 16, 2007
  • Mar 16, 2007
short the connector on the low side switch and see if the compressor runs.. ONLY do this for a few seconds.
D
dave_id
44
#10
  • Mar 16, 2007
  • #10
ok ill get that done when i get back, thanks
Mike97gt
it doe snot
10,633
Mar 16, 2007
#11
  • Mar 16, 2007
  • #11
cool, keep us posted.
D
dave_id
44
#12
  • Mar 18, 2007
  • #12
k, I got back and shorted the connector at the low side port. The clutch came on, the car jumped to 1,100 rpms then dipped back down to normal idle and the air was still hot. But the clutch stayed on. So i grabbed my bottle of r-134 with a gauge on it and connected it, and the gauge read that it had some r-134 already. Now what?? Thanks a lot
2002tbstang
26
Pebble Beach
Mar 18, 2007
#13
  • Mar 18, 2007
  • #13
Next you need to turn on the AC all the way up an let that go for a little bit then start putting in that gas stuff while shaking the bottle. I did this a couple days ago, I was tired of hot air comin out when it was already gettin hot outside
Mike97gt
it doe snot
10,633
Mar 18, 2007
#14
  • Mar 18, 2007
  • #14
check to see if your high side switch is working correctly.. then if thats working fine, your probably just low on freeon
D
dave_id
44
#15
  • Mar 18, 2007
  • #15
k cool thanks guys
Mike97gt
it doe snot
10,633
Mar 19, 2007
#16
  • Mar 19, 2007
  • #16
forget what i said about the high side switch, I must have been smoking crack or skim reading again or both..
the problem is you are low on freon.
D
dave_id
44
#17
  • Mar 19, 2007
  • #17
so since there is a leak, should I try to find it first ??again, thanks a lot for the help
its gettin pretty hot
the98stang
2,408
Clovis, CA
Mar 19, 2007
#18
  • Mar 19, 2007
  • #18
A shop needs to evacuate the system. They will fix the leak, and recharge the system.
RED2001GT
20+ Year Stangneter
Mar 18, 2003
270
Mar 19, 2007
#19
  • Mar 19, 2007
  • #19
What does "evacuate the system" mean? And HOW can a leak be fixed without replacing the A/C Compressor? I would like to know.
Nathen4.6
34
Central Florida (352)
Mar 19, 2007
#20
  • Mar 19, 2007
  • #20
JB Weld
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
