Moved to tech..
a couple of things can cause this
But if it's above 80 out or really humid try using the max a/c setting and see if it goes away. sometimes if it is really humid using the outside air might not work as well
What you are seeing is excess moisture from the process of the air cooling, as it cools it can't support the extra humidity so you see this as water vapor
