air conditioning delete
  • Thread starter Thread starter kpack5982
  • Start date Start date Aug 13, 2005
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Aug 13, 2005
  • Aug 13, 2005
I know I can delete the a/c, but I don't want to take it off right now, I just want to bypass it for the cooler months out of the year when its not neccesary. Can I do that by just routing a shorter belt around it, or is that going to be hard on the a/c or engine? Any little extra horses are fun to free up
stang22
1,318
Washington, D.C.
Aug 13, 2005
  • Aug 13, 2005
I don't think you can just bypass it like you can the smog pump. Your tensioner will not work right when the belt runs from the P/S pump to the alternator. That's why they made the kit that moves the P/S pump so you can utilize the tensioner.
Tim
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Aug 13, 2005
  • Aug 13, 2005
No need. You won't pick up anything by bypassing it and leaving it there even if you do figure it out. Either ditch it completely or leave it alone.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 13, 2005
  • Aug 13, 2005
If you want to bypass it, then don't turn it on!
Seriously, take the belt off and spin the pulley. It freewheels when the A/C is off and should spin quite easily.
So leaving the A/C intact just gives you another idler pulley.
There is NO HP difference between a car with a/c and one without a/c when the a/c is not running.....just a weight difference.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Aug 13, 2005
  • Aug 13, 2005
You took the type right out of my fingers.
The "gain" people talk about with a A/C delete is actually a loss, a weightloss be be exact. The A/C and all it's components togeather is heavy, and sits in front of the wheels. You also delete the clutter under the hood.
I say, if it's a street car, and the A/C is working fine, then keep it, but if it goes out, and it doesn't mean that much to you, scrap it. The compressor went out on mine, started leaking oil and making noise. Usually when that happens debris gets scattered through the system, so everything would have to be replaced or I would be eating up new compressors, and since I never used it anyways, I junked it all. Now the car has no HVAC period.
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
M
Air Conditioning parts source
  • mustangmark68
  • Jul 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 1, 2025
mustangmark68
M
